OK, my A/C compressor locked up 2 years ago and I have come to grips with the fact that I am not going to fix the A/C in this rig. So, I wanna remove it... namely the cooler in front of the radiator. I would like to get that out of there so that I get more airflow through the radiator at crawling speeds on those hot Moab days of wheeling. Can I just have the freon evac'd and then pull the lines and remove the cooler? I assume so since I am not worried about contamination getting in the lines (the A/C never will be used again). Could probably even pull all the lines and stuff too, right? I am sure this shouldn't be a prob, but want some advice before I do it and go "uh-oh." BTW, not interested in converting to on board air, already have CO2 which I like far better. TIA, JP
