scott00tj
- Medina, OH
How necessary is it to use new bolts when replacing the leafs and the shackles? I saw on site they recommend using new hardware whenever making the swap.
I'm talking about the "Rear Leaf Spring Shackle Bolt & Nut". On Team Cherokee's site is where I saw it saying they should be replaced.
That said, if your Jeep lived in the north and saw a lot of salt, plan on the bolts being seized into the bushing and you'll end up cutting them out...
12 years of Ohio winters.....![]()
Agreed on everything except the last paragraph... TJ ones are NOT the same. Neither are ZJ iirc but not sure on that. TJs use cam bolt adjusters on the LCAs...The bolts aren't under elastic load so it's not really a question about torque yield stretching.
They are under shear load so it is a problem if they are severely marred or pitted or rusty. You don't want to snap one at the threads, trust me.
Dealer charges about $15 per last time I checked. Luckily the LCA bolts are almost the same, just a little bit shorter but plenty long. You can get like-new LCA bolts from XJ/ZJ/TJ/WJ at the junkyard all day long for free. I picked up a bunch from soccer mom Grand Cherokees that still had the factory zinc coating.
