Maz
- LaCanada, CA
I am the original owner of my 1989 Pioneer. 4.0L, AW4, 231, 3.54, 215/75/15, bone stock, 280K miles. She has been on Penzoil 10-30 and Fram filter diet (which I'll switch with the next oil change) all her life, with an average of 3.5K oil and filter change intervals.
She sat for 18 months, and I recently got her started so I could get a smog certificate and renew registration. She was getting 18mpg, mostly freeway, before being side-lined.
She is a far cry from being "jack the rabbit" she was in her glory days. I am trying to find out if the engine is just too old and tired (therefore requiring a rebuild), or, if there are things I can do to bring her back to the best she "can" be, given her age. I am not looking for performance mods as I think it would be a waste of money on a tired engine. I am looking for advice on the logical sequence of things to R&R from cheapest (most likely to re-fresh) to most expensive being "don’t waste your money, she is dead." I am also trying to find out if her lack of power is engine-related or tranny-related, so I can focus on one or the other.
Here is the best I can explain the sluggishness. She accelerates fine (normal) on both flat roads, or climbing hills. She will get up to 80mph, climbing hills. However, if I step on her, she will only climb up to 3000 rpm. If I really-really floor the gas, she will spike to 3500 rpm, for 1 second, and then jump back down to 3000. The older days guts is not there.
She also makes a very loud "growling" noise, which is more pronounced under load. I am only including the noise here, in case there is a relationship between slugishness and it. The best I can describe this noise is that it resembles a bearing going bad but very muted sound. To me it appears to come from injectors and is not the typical ticing noise.
Here is a long list of her condition, based on lots of search and readings; anticipating your questions. TIA for reading my long thread and I welcome all, or part feedback, with suggestions.
I figured first order of the business would be a compression test. This is how I did it. Fully charged battery, engine warm, all spark plugs out, throttle fully open (gas pedal fully depressed), fuel pump relay out.
Readings:
(PSI) Cyl 6 to 1 (back to front)
Dry test, 2-3 cranks:
120, 107, 145, 110, 137, 127
Dry test, 5 cranks:
130, 110, 155, 120, 150, 135
Wet test (a bit of 10-40 oil in each cyl), 2-3 cranks
127, 125, 140, 130, 155, 140
Wet test, 5 cranks
130, 140, 160, 155, 170, 160
Factory specs call for 120-150 PSI with no more than 30PSI variation between 2 adjacent Cyls.
Oil pressure is:
42 psi cold idle
20 psi warm idle
45 psi highway speed (65mph)
Do I need to do a leak-down test? Do I have worn rings? I know the numbers say she is tired, but that shouldn’t limit the engine speed to 3500 rpm, should it?
Oil consumption:
She loses about 0.5 quart every 3000 miles. For the longest time I thought it was the combination of the rear/front seals and some oil burning. But after checking behind the valve cover, there is a lot of goop there. There is no smoke when she is warmed up.
Crankcase ventilation system (original)
I don't know if she has "blow-by". There is a bit of oil at the edge of the air filter.
IDLE
She’s never had high idle problem; if anything, she has a low (rough) idle. Cold idle is 750 rpm. When warm, the engine speed fluctuates 600-750 rpm, with a variable engine hum (is this called hunting?), with some engine vibration.
Maintenance history (with R&R mileage). I am trying to give all pertinent info.
FUEL:
-Fuel filter, changed every 2 years (10K miles since last change)
-Fuel pump (original), pressure: 35 psi, regulated
-TB, never taken off, or cleaned, it’s black in there.
-No FI cleaner has run through the fuel system
-Replaced injectors (106K miles)
-Corroded FI harness ends (see pic)
-Throttle valve cable (never adjusted, see pic)
-Fuel pump ballast resistor (original)
Note: She won’t start 1 out 5 tries until I wiggle the harness at No.6 FI. The dealer was unable to fix that (without explanation) and I’ve lived with it for well over 10 years.
IGNITION:
-Spark plugs (Champion), cap (OEM), rotor (OEM), wires (OEM), all changed every 2 years (10K since last change).
-Distributor (original, never taken off).
-CPS, (8K miles)
-Throttle Position Sensor (TPS, 201K miles), voltages:
-Manifold Absolute Pressure (MAP) sensor (original)
-Inlet Air Temp sensor (original)
-Engine knock sensor – (original)
-Idle Air Controller motor (original)
-Oxygen sensor (79K miles)
-Coolant Temperature Sensor (12K miles)
-Manifold Air Temperature Sensor (original)
-Cam Position Sensor (original)
TRANSMISSION:
-Fluid changed every 2 years (40K-45K miles).
-Filter changed every 4 years.
-She has had ATF (non-DEX) fluid most of her life. That’s what I get for trusting shops to know what the correct fluid should be.
-I replaced the fluid with Chevron DEX-III, last week.
-TPS / TCU ground by the dip stick is clean
-Fresh 7.5 amp TRANS fuse in the fuse box
-Catelytic Converter (79K miles), there is no rattle when I hit it.
-Muffler (84K miles)
-Air filter (10K miles)
-EGR Solenoid (brand new)
-Vac lines, (some original, some about 190K)
From my research, the possible causes of my engine/tranny behavior can be:
1. A plugged catalytic converter and/or muffler (easy fix)
2. Bad/out-of-calibration TPS (easy fix)
3. Throttle valve cable adjustment (easy fix)
4. Bad torque converter (completely clueless here)
5. Worn out distributor (completely clueless here)
I know Martin will tell me to replace all sensors. I will if ypu guys tell me there is life left in her. I also need to R&R the entire crankcase ventilation system as well as the vac lines.
At minimum, I am going to start her on BG44K/MMO/Seafoam fuel injection cleaning diet, and internal engine flushing using the synth oil method.
So guys, where do I start? Engine or tranny, and what do I do, and in what order?
Thanks a million for staying with me on this long thread.
_Maz
Readings:
Dry test, 5 cranks:
Wet test, 5 cranks
Oil pressure is:
42 psi cold idle
20 psi warm idle
Oil consumption:
IDLE
FUEL:
IGNITION:
-CPS, (8K miles)
TRANSMISSION:
_Maz
