Bob Langford
- Roanoke, VA
....on a '96 XJ. Thanks to someone's tip about use of breaker bar on the frame, removing coil wire, bumping starter a little. The center bolt spun right out ! And the thing came off ok with Autozone harmonic balancer puller rental. Question I have now is this: what makes the key come off the crankshaft ? And does it absolutely need to be replaced with new harmonic balancer ? And, if using the bolt to pull the new HB back on is not recommended, what's the preferred way to do it ?
Thanks !
Thanks !
