Replacing J10 TRE with Heims.
I assume you have flat top knuckles on your 44? If so, get an aftermarket steering arm set that allows a separate mount for both draglink and tierod. The bolt holes are probably 5/8, so either get a 3/4" bore heim and sleeve it down to 5/8" or get a 3/4" thead 5/8 bore. Use high misalignment spacers either way.
If this isn't what you were asking, ignore it :D.
Nay
