Renix to HO TPS swap...who's done it?
Gil BullyKatz
I've seen a few different ways to do it...
How did YOU do it?
I cut up and slotted the shaft on an HO TB to the point where the Renix TPS bolts right up to it...
still unproven tho as the engine isn't done yet...
I'm thinking about going with a 70mm Ford TB and was wondering if anyone has tried splicing the TPS wires...
IIRC the Renix only has 2 wires right?
the Ford has 3?
:dunno:
When I bought the heep three wires had been saudered and one plug was eliminated from the tps. When converting to HO I bought a new tps with two plugs and spliced. It worked just fine.
I decided to add spacers and mate the HO bushing to the renix tps
the renix does have 3 wires. and it works fine. the only issue is w/ an auto, the renix has that other connector for the tranny.
