Renix Performance Computer
There was (discontinued, none left) a MOPAR Performance computer for $400. There is NO chip available for the Renix - AFAIK. I have been testing mods for 3 years before I installed the stroker and these are the best I have come up with - in this order.
K&N flat filter in stock airbox - this gets cool air from grille on Renix models
Remove venturi in air box snout.
Install Hi-altitude CPS - 8 degree ign advance.
Install Dynomax 2 1/2" super turbo cat back.
At that point you need more fuel so build an adjustable MAP and adjust (5.8v or so) to pick up performance.
Then hi-flow cat and Headers are next.
That will cost less than the $400 computer and provide more HP than the 10 -12 MOPAR claimed for the computer.
