XJ91
- G'Nagiwanka
I'm going to be putting degree shims on my rear leafs. Is two C-Clamps enough to hold the leafs together? While I remove the pin and incert the * shim? Also, Do I need to remove the leafs from the jeep or can I just remove the U-Bolts and drop the axle?
I will be replacing the u-bolts with new ones.
