Removing pinstriping.
hamilton
Got tagged in the door, and body shop wants $800-$900 to repair and repaint it, so I grabbed one in the same color from a junky.
Only difference is the presence of gold pinstripe tape on the clear-coated metalic green paint.
Anyone know how to remove it without jacking up the finish?
Thanks in advance,
Hamilton
Use a heat gun (or hairdryer) to *gently* heat the stripes up,then peel 'em off a little at a time. Get some adhesive remover (like 3M A.R. or Goof-Off) and rub off the excess adhesive and you're done. You may notice after they are removed that you'll still be able to "see" where they were. A good buffing of the paint to remove any oxidation in the clear coat should remedy this.:D
at auto paint stores they sell decal remover tool. its a big round rubber eraser that you put on electric drill. it work great and fast. jack
out here in cali durring the summer I just peeled mine off because it is nice and hot. And zippo fluid works great forthe adhesive.
