Removing 92 xj windshield trim
You should use a tool like factory recommended for my 1990 the tool is J-21549-3. there is a drawing of the tool in the factory XJ manual in the body section.
https://www.f-body-power.de/new_med...body_manual/17 1969 FIB-Exterior Moldings.pdf
see page 4 and 5 of above link, see image of the tool there, the Jeep tool is same as used on some GM cars, see chart on page 4, image on page 5 in link above
you might try ebay or make your own...
https://www.ebay.com/sch/i.html?_nk...4%26rvr_ts%3D7b3a68921710a9cd5fc73c28ffd79b9c
https://www.ebay.com/itm/Kent-Moore...&_trksid=p2047675.c100623.m-1&redirect=mobile
You should be able to fabricate a tool from a strip of thin sheet steel. Use the above links to get the shape down. basically some bends and grind away a hook on the end. Make a handle by winding thick duct tape around it.
or grind a hook on a inch inch wide putty knife The putty knife should be thin enough, and stiff enough to work fine, a dremel, file or grinder can cut the hook needed to get behind the trim clips. putty knifes are a buck or two each at ACE, and the already have a handle!
