Removing 3M moulding tape
OT
Jensen, UT
PITA by hand. Hurts my fingers trying to rub it off. There has to be an easier way. Tried adhesive remover to no avail. Secrets anyone?
If you don't care about your paint - use a razor. You may even be able to buff out the stratches with rubbing compound. Never tried it myself though...
YOU CAN GET A 3M ERASER WHEEL AND AIR TOOL FROM A AUTO PAINT SUPPLY STORE. TAKES IT RIGHT OFF. WE USE THEM IN THE BODYSHOP I WORK AT.
GOOD LUCK.:D
The 3M adhesive remover works great,as long as you don't follow the directions on the back:rolleyes: The stuff I'm talking about is in a liquid form and comes in a metal quart can with a spout on top,not the aerosol can kind(that stuff sux). Anyway,soak the adhesive with the solvent and keep it wet for a minute or so and it will start to break it down. You'll still have to peel it off,but it'll be much easier than without the remover. It gets kind of messy when it starts working. It'll kind of remind you of those neuclear boogers that won't flick off your finger no matter how hard you try:D
