- Westminster, SoCal
OK... I was looking at some tables that are floating out on the internet and I can't make heads nor tails out of it. I know they are meant as a starting point, but if I have fixed LCA's how do I adjust the UCA to them to start? Do I look at the table and measure my LCA and use that as an entry point instead of the lift height?
So if the LCA is about 16.25 (give or take a little bit) then I should use about 15" for the uppers for the starting point? Btw... I'll be probably sitting on about 4" to 5" (not sure how it will end up) and it's the front RE SuperFlex lower fixed and SuperFlex upper adjustable
Lift...........Lower Control Arms/Upper Control Arms
Decimal Fraction Decimal Fraction
Stock..........15.75....15 ¾.......15.00....15
3”...............16.09....16...........14.92....15
4”...............16.33....16 3/8.....15.03....15
4.5”............16.47....16 ½.......15.11....15
5”...............16.62....16 5/8.....15.21....15 ¼
