Milford Cubicle II
- Out there.
You are concerned about decreasing NVH off road?
Who said anything about NVH off road?
The OE manufacturers have been using structural foam sometimes referred to as pillar foam to reduce NVH, increase structural rigidity, and provide additional side impact protection. A similar product has been developed for military vehicles to protect our troops. I think 3M or Loctite are marketing a product to repair newer vehicles manufactured with the foam. Possibly, the repair material could be used to fill frame cavities, pillars, etc to reduce NVH. Probably someone working at a collission repair shop could share their experience with the foam
I'm thoroughly baffled. Just where in the hell do you drive on or off-road where you never turn at full lock??? :huh:
Do you know what "full lock" means? Serious question.
For the love of God, do not use the Daystar poly tranny mount(my @$$ is tired of it, even though it does prevent rocking under torque).
Load range on the tires seem to be a reoccurring theme.
I've looked all over tire shack and the lowest offroad worthy 33' by 16' tire I can find is a "D" (what I'm using now). Is there anything available in a "C" range?
How does this foam stuff not promote rust? Other than that it sounds great.
You can either have sexy looking rims (Moabs) or have a soft tire (Load Range C), but you can't have both.
I know this because I have Moabs and wish I could get Load Range C, but I am stuck with D thanks to these wonderful rims.
I noticed a big difference in nvh reduction when I did my frame stiffeners.
Also, I have a rock hard 4x4 cage, that really cut down on the body groaning and twisting.
you could always leave your purse at home and be a man about it...
... and you could contribute something instead of being an ass.
