CMNCHE
- Pennsylvania
I recently aquired a 91 Dodge Ramcharger with 4.56s and 35s. The rear axle is a Chrysler 9.25....I bought it knowing it need rear gears (along with a bunch of other things). I had parts and fixed most of the downfalls, but the rear axle howls quite a bit while on the gas (hardly at all coasting).......My question is how long do you think I can drive it like this. I have Dana 60s but I need 8 lug wheels and 16" tires which are not in the budget at the moment. I pulled the cover and the gears look ok (no chiped teeth) but are worn funny. The teeth are worn all over instead of in the usual pattern. I believe the diff was set up wrong and then re setup. I hate to spend $200 on new gears just to swap axles in a couple months. I searched other fourms but none are as good as naxja, so i figured Id ask here.
