maxbraketorque
- PDX
The hitch will add strength but your sacrificing ground clearance. The factory nut-strips are 1/8" and utilize all 5 mountings bolts so you went to a lot of trouble without any gains.
BTW, your Curt hitch doesn't use all 5 bolts!
I agree that a standard style nut strip will keep the nuts from pulling through the unibody rail, but that's the extent of it. I can twist and bend the factory and JCR nut strips by hand. The nut strip I'm using will add twist resistance and will reduce the amount of flex that can occur at the unibody rail due to more effectively clamping the hitch to the rail. I'm certain that it will provide more benefit than a standard nut strip, but I have no idea how much it will help compared to the innate stiffness of the unibody. I contemplated gusseting the Curt hitch to help with twist resistance, but I decided to wait and see it works as-is.
I'm ok with giving up some ground clearance. There are no obstacles that big or angle of approach/departure that steep in my expected future. Probably goes without saying that if I ever scrape the hitch, I probably should have a gas tank skid, so its a good warning indicator.
