Rear shock valving question
toyotawrench
anaheim ca
Hey everyone, my set up
Front: 5.5 deaver JS coils
10inch fox 2.0 pro
Rcx drops.
Rear 3.5 inch rubicon express full pack
Re heavy duty 1.5 or 1.75 shackle
10inch fox 2.0 pro
Here is the question, My front works well, but the rear is far far far to stiff, I am going to rebuild, and re-valve the rear shocks, but what valve to get? I am all stock inside, no cage no bumper, box with a 12 inch sub, and my spair goes inside also. Thank you in advance for the help guys.
yea the valving in the shocks were for a fully bed caged pre runner 1500 with 2 37 spairs in the rear, they are to stiff, need to revalve them, they are to stif on the road to stiff in the dirt, they are to stiff.
What valving is in the rear Fox shocks now?
Have you tried disconnecting the shocks and going for a drive? (Obviously keep speeds limited.) Just curious if the ride softens up more to your liking... maybe the springs are too firm???
I know shock tuning can be a pain, but if their rebound valving is so slow as to keep the springs compressed to a high rate it sounds like they'd be so far off target as to be a defect.
no clue, bought them used
I'd call Fox and ask them what they recommend. Fox has application specific 2.0 shocks, and they can get you close. Fox uses a scale to specify valving, like 30-35-40-45-50 etc, the higher number is stiffer. They should be able to tell you what the valving is in a shock that is for your application. They show the same valving for an XJ/TJ/ZJ which should be better than what you have now. Fox sells the valving stacks for both comp and rebound for each valving, and they're cheap, like $5.
well after a talk with grimmy last night we determined that my shackle angle is super bad, and I am in the process of finding some boomerang shackles, if you have some let know, check out the angle >.<
thanks again everyone
peace
ted
how will boomerang shackles help the angle? it will LOOK different but from bolt to bolt the angle will be the same, or very similar
