???Ok i got everything off changed the seal replaced oil pan
did you replace the oil pan gasket or the rear main seal??
ok i will take advise, i need help again, the darn thing still leaks, it appears to be comeing from the bell housing, possibly the rear half of the oil pan
thats were the rear main leaks. if you changed the rear main(which im not sure if you did) it could be just some residual oil still in the bell housing.
