Rear lower shock nut size?
I always understood you should only use aluminium anti-seize on stainless.
No, stainless and titanium use a nickel based anti-seize but since he's going steel/stainless anything is better than nothing!
Why use the correct anti seize if he refuses to use the correct hardware?
If it’s on there, leave it alone.
Its not really about whats right or wrong, its whats available and will work. Reality is, they’ll prob get changed again when i lift and replace the shocks. Or be taken off and put back regularly enough that it wont matter much 🤷🏼*♂️ its a jeep, “held together by hardware store nuts and bolts” kinda goes with ownership ;)
