Mike from Chile
- Santiago de Chile
My xj year 2000 has a 3,5 RE lift + 2 inches spacer in the front and a shackle in the rear. Tires = 265/75/16
From the center of front wheel to the base of front fender it measures 23,5" and same procedure taken at the rear measures 21,5".
By the moment no vibrations experimented, but just a little wobble when bumps, probably because of longer LCA and UCA needed.
Question: If I raise the rear to obtain the stock angle of the body will the driveshaft angle cause Vibrations?
Thanks
Thanks
