Jeff 98XJ WI
- Butternut, WI
Hey all, I just thought I would post up a link to a bunch of pictures of my rear HP 60 project. I made a significant step forward last night by pressing out the short side shaft at the local high school auto shop. I used their 50Ton press. It took quite a bit of work just to get the housing in the press, but once that was accomplished, actually pressing out the tube was easy! It moved with much less hassle than I thought it would take. The problem with getting the housing in the press was that the housing was too long. I had to remove the springs that pull the press shaft up, the plate that the springs attach to, and a snap ring that the plate fits against. Then, the press shaft would fit inside the long side tube. I had to remove the presses feet in order to move the table to it's lowest set of pin holes and then I had to tip the whole press partly over to slip the housing in place and get the press shaft into the long side tube. I also placed a piece of pipe inside the long tube which pressed on a couple adapters that fit against the short tube seal area. Prior to this pressing operation, I had to disassemble the HP Dana 60 front end, cut it's ends off, remove all bracketry, and cut the plug welds out on the short side as well as clean up the resulting holes. Enjoy the pics. Jeff
http://share.shutterfly.com/action/welcome?sid=8IbtGzVo3bMYQ
