I have removed everything out of the back. I have adjusted the hatch stops. I have stuffed tons of rags in between the plastic and the hatch after I tightened down all of the trim screws. I think the hinges are causing the rattle. It sounds like the hatch isn't closed when I hit bumps. The stealer wants $50 a piece. Any ideas on shimming the old hinges? I already wedged c-clips around the hinge pin but it isn't enough to take out the play.
It's a 2000 and although I wheel it. I fawking hate rattles! :rattle:
Any ideas?
Thanks in advance,
Brian T.
P.S. Before you flame me, I did search first. Just didn't find an answer. :lecture:
Any ideas?
Thanks in advance,
Brian T.
