rear four link using rusty's front long arms
a_boy_named_sue
indio california
does any one see a down side to the y-style 4 link set up that rustys offers for their front long arm being used in the rear?, (any prob w/ clearence anti-squat and axel location or anything else?). other then price and bracket fab.
When you triangulate your control arms, you shouldn't need a panhard bar. However if they are just going to be trailing, you will need a trackbar, or a panhard for sure.. I think? :)
ummm. Are the long arms for the front designed to connect to the UCA brackets? They wouldnt be the same for the rear so you would need to do some fabrication for the mounts.
They are not triangulated so you will definitely need a trac bar.
Lots of anti-squat in the rear I would think.
Panhard......track bar......
I'm in on page one too.....
BTW, people do run radius arms on the rear of all sorts of rigs.
Most are in simple redneck-rock-rods on 44s that have more horse power than traction, that rely on momentum and don't care much for articulation.
Why on earth would you want to?
It is very easy and relatively inexpensive to build you're own links. They can be built to the design of the suspension, rather than designing a suspension around existing (not very ideal) links. Links are made by folks building custom suspensions all the time....it is very common and much prefered.
not really sure what that means but all you smart guys are doing it, so I'll try also.
Chris
Chris
hell why not? me too then :D
but on a serious note i don't see why you would run a raius/trailing arm design in the rear when all that design work could go to a triangulated system
If the radius arm is flat, so not alot of angle from the axle to the frame, then it will not have HUGE anti squat. It could be long and maintain all the facory floor, It would could have better axle control and ride then leafs, especially if you had a lift block.
My buddie had an all y-long arm kit on his grand cherokee. 35s, mybe 7in lift. It rode really soft and nice. Could this work on my cherokee with 42s. no way it would suck, and I wouldent get 16in of travle out of it but on a fully boddied cherokee for milde trails 10in travel it would be nicer then leafs.
Chris
Some are not smart
Cruzin Illusion said:
Some are not smart
It's called "knowing better".
Think about it, any thread that has both, Rusty's AND radius arm rear-ends has gotta end up being a multipager.
But, any thread in which, someone asks about using Rusty's front radius arms for a rear link setup is an instant classic!
Id look at a one link too. I run it and with a rear winch and limit strap it has been GREAT not to mention pretty easy to fit to an XJ.
without the rear winch, Rusty doesn't recommend using the front links in your rear on less than 8" of lift.
