HQuakers
- South Jersey
For some reason I decided I wanted a rear fog. I have a Draw Tite hitch and I got one of those LED hitch brake lights since I needed a plug and I had the wiring.
I wanted to keep the brake light setup, but add in a switch to keep it on in inclement weather. I ran the power through the switch since it's rated for 12V and the hitch light is LED. I ran a single wire up the top left of the Jeep behind the trim, which made running the wire quite easy. I put the switch below the factory rear wiper, rear defrost, and fog. I plan to add all my lighting switches here as it's convenient and there's plenty of room. I also put in a trailer wiring kit between the stock plug and the LED so I didn't have to hack into any existing hitch wiring.
Hitch light I got at Harbor Freight for $10:
Wiring kit between the two:
Lights On, Switch Off:
Lights On, Switch Off, Brakes Applied:
Lights On, Switch On:
Lights On, Switch On, Brakes Applied:
Switch location:
I'm super happy how it turned out, and for under $20 I have a plug for the hitch when not in use, another brake light, and a rear fog light. If the LED goes, I'll just go buy another for $10, though I don't expect it to break any time soon.
Switch location:
