- NC Sandhills
" noticed something a while back that might relate to your problem. If you look closley at your pic of the shackle, you will see the bumper bracket bolts sticking through into the box that the shackle mounts in. As you compress the spring, the shackle moves back, directly into one of the lower bolts. Call it a design flaw in the shackle if you want, but you either need to notch the shackle to clear the bolt, or whack the bolt off with a grinder or sawzall."
Ya I found out this was why my revolver shackles werent revolving...they hung up on the rear bumper mounts (not factory) and severley limited the swing of the shackle. I removed the shackles to sell them, then removed the bumper to 'clearance' the mounts...installed some MJ shackles and flexed it up w/o the bumper on there...WOW what a difference. It rides SO MUCH better on the road now that the shackles & springs have free movement. Also agree with JnJ to check that the shackle bolts aren't too tight.
FWIW I am running 4.5" Rusty's pack with an extra leaf that nets 6" approx (with approx 400# of 'junk' in the back)
Thanks all for the Track Bar advice...mine needs some attention to the mount clearance...
