anthrax323
- San Antonio, TX
When you performed the swap, did you replace your axle shaft seals? If so, did you use OE parts or aftermarket?
Aftermarket seals typically do not have flanges and can be installed backwards. Make sure you installed them with the seal springs facing inward. If they are installed backwards, they will leak and kill your pads (ask me how I know).
