pokeyxj
- Albuquerque, NM
I converted my 01 xj to rear discs using the rear set up from a 96 ZJ including swapping the prop valve internals. Everything went pretty smooth. I ran the XJ while the rear was up on jackk stands, the rear brakes worked. The real test is driving. The rears will not lock up like the fronts. I bled the rears again with no improvement. Any ideas. Did I over look something?
