Magus2727
- Draper, UT
With the old drums and 33" tires were not helping me stop and finally needed to get around to getting new shoes. Thought I might as well use the C8.25 29 spline rear end I have had laying around for the last few years to good use.
Grabbed the rear disc brakes off a 98 ZJ in the local junk yard.
Got all new pads and rotors. And ebrake cables.
Had to make the opening a bit larger on the backing plate. Used a few of the guides to get this far.
Some questions though. Is the rear brake line splitter block different at all from the drum vs disc?
Is there any special or correct way to adjust the parking brake before it's on the car? Guessing you want it to engage about 1/2 way through the ebrake levers motion?
I am going to see how the brake bias works as is, don't have the ZJ perprtional valve (forgot to get it as the junk yard).
Is there anything I have missed or need to watch out for?
Thanks.
Thanks.
