Harvo
- Chattanooga
Missed the question. Mine is a 93.
johnsoninc86 said:I did the zj disc swap on my 98 w/ 8.25 and my 32's lock up before the fronts. I took out just the o-ring in the prop valve. It's a little wierd feeling the rear end want to swing around in front of you, but as long as you expect it, its okay, and it still stops on a dime. It's kind of getting on my nerves, thats why I've been watching these threads. I might try the adjustable prop valve from Summitracing and see if that helps at all. If not, then back to the junkyard for a zj proportioning valve.
Slonopotam said:How do you understand your brakes are well balanced ? Is there a test procedure "for dummies" written somewhere ?
Thank you
That's the problem with questions like this.Ray H said:Settle down. It was an off handed comment about your originallity. Its not a bad thing. I do appreciate your comments, thats why I asked. I was just saying that its going to be difficult to come up with a definate answer because there will be so many different combinations.
Hugs and kisses.![]()
mmmkay325 said:I have a 96Xj w/ abs and d35....put a d44 in the rear out of 87xj, swapped out the drums for 97zj discs. Drove it like that for a year. Never really happy w/ brakes. Seemed to glide more to stop than stop, so i swapped out a ZJ proportionaling valve meant for disc all around, that was the ticket!!!...made a hell of difference. So i'd so go that route and see if your happy.
Dirt Surfer said:Can Someone tell me this: I have a 2000 w/ ABS. Will be putting axle with disks in rear. I have a prop valve and MC/booster from a 98 Grand that had 4 wheel disks.
1. Are the MC/boosters the same in new Grands and XJs. Is mine the same as the 98 MC/booster in my garage?
2. Should I remove the o-ring in my prop valve, or use the prop valve from the 98 Grand that had disks.
Will be ripping out ABS and replacing lines soon, so anything else will be simple.
Which year did you take the rear from ?natep1 said:00XJ, 30's, 8.25.
GC rear setup, stock m/c & booster, adjustable prop. valve.
