Trying to get a few ideas on how to build some longer stops for my rear.... I changed the shock location and now it flexes into my fenders and now i need to bump stop it....
i got some numbers for my rears this weekend when i flexed her @ hunter lake trail! but i think i need to add 2" more as i am gonna be runnin 35s, so far i think im about 10" total on my stops! ughh..( square tubing bud)
Get some 2x2" square tubing and make a large spacer for the current bumpstop. Or weld a 2" wide piece of steel that sticks out from the spring plate on the top of the axle.
It raises the bumpstop from the top of the tube to the top of the spring plate. My guess is that it is close to a 4" raise (thickness of the perch, springs, plate, and welded material on top). If you need more, just drill a hole in the material and add 1" thick hockey pucks. You can get the extended stops at any 4x4 shop. This isn't rocket surgery.
i bolted a piece of 2x2 to some 1.5x1.5 to make it 3.5" longer. then bolted that to the 1.5" longer bump stop that i had already previously installed to make it about 5 longer than stock. it was basically free. id reccomend it for the type of wheeling you do (crawling(no go fast) while trying to keep the jeep cheap as possible)
