tone
- La Quinta, Ca
Where are you guys mounting your rear bump stops/strike pad at? I know it has to be stock location, I'm just trying to figure out how to go about doing it?
Usually, they hole saw through the center of the frame, right up through the floor boards. Put a bump can mount in and weld it in place, then plate the heck out of the surrounding rail. They also run a tube from mount to mount inside the car, and attach it to the floor.So cut/notch out the unibody and counter-sink the bump and weld it in?
Look at t&js kit and copy it
or support avendor and buy it from T & J's, lol.
BAD RYAN! :twak:
Thanks for the info I've been surfin around the jeepspeed forums too. As for strike pad, what are most using? Ex: Leaf spring plate like full tractions where it has a raised bump stop mount. And what size stroke is more common for a bump in the rear 2" or 4"?
