GI-John
- Mount Holly, NJ
Moog 1312 (ZJ Tie rod end from drag link to LS)
I replaced the block off plug with a zerk on the end of the TRE, but the end has a hole drilled into the side of it that is not threaded. When I try to lube it, grease comes out. I'm thinking that there should be something there to allow the grease to move into the joint.
Should I just tap the block off plug in?
Thanks,
John
Thanks,
John
