Reader's Rig's
WhiteKnight, that looks like a very solid and well built rig, nice find!
Also diggin the Ram too....always have like the looks of those things lifted...
GrimmJeeper said:
rustys 6" glass front fenders
man im diggin your stuff !!
peeweexj said:
That is a real nice looking Cherokee!
Your front bumper is a Rocklizard Monitor front bumper
Your swaybar discos are JKS Quicker Disconnects
Your sliders are possibly Rocklizard also
Lights appear to be IPF 968's
Steering stabilizer is Old Man EMU
Edit:It appears your springs/trackbar are gray in color. If so, that is a Rubicon Express lift. Your upper/lower control arms should also be gray.
Excellent info!! Your right on the discos, stabilizer and everything underneath is grey. I was told the front bumper was a Rocklizard. How much lift do you think it has???
Thanks everyone
I have seen pictures of your dodge on the pavementsucks site. I also drive a dodge, but am now wheeling an xj. Mine is set up similarily to your new xj and I've been really happy with the capabilities. Nice rigs.
Whiteknight said:
Just wanna say this is a great site guys!!! I just bought this XJ on the 30th. Don't know to much about it yet but heres the specs i know
-35" MTRs on black steelies including a fullsize spare
-offroad front bumper w/2 nice bright lights and tow points
-a nice set of rock sliders
-not sure of the gears all i know is its powerful
-not sure of lockers but i think the rear 8.25 is locked, not sure untill i pull the covers
-sway bar quick discos
-roof rack i had from a different vehicle
Sorry about the poser pics we haven't gotten the chance to get it offroad yet but it will happen soon:eeks1:
Heres a pic of my old rig
It got wheeled hard and ended up being a trailer queen. Now with this XJ I want to be able to drive to and from trails. We are actually planning a trip to colorado sometime soon. The XJ is my DD,hunting/wheeling/family rig. Im sure it'll be fun. I will tell you i am realy glad i bought it so far
Welcome Aboard Whitknight, I'm HotChiliRam from PS, long time no see.
Nice XJ man, you will love the Off Road capabilities of this things. :)
I don't have any picture of my cherokee when it was stock, but heres one of it with just the lift.
Here it is with the addition of a Rusty's steering stabilizer, 31 inch bfg AT's, soft 8's and a Surco Roofrack.
I bought a second hand 4.6 stroker and M.O.R.E. motor mounts.
Put it in.
Here it is with a blacked out front.
Took off the bumper, cut the fenders, JKS discos, BDS trackbar, TC drop, and more stuff that i forget.
Very nice XJ, my buddy has a Ram just a bit bigger. He's a poser though, he doesnt take it out just drives it around town. Gotta' set up 39 TSL's on it.
BTW: Is that a cop car behind your XJ?
Egg
88 cherokee 2 dr
rubicon express superflex 3.5 kit??
with 1.5 coil spacers up front
swaybar disco's
stock welded vaccuum disco 30
stock welded 35
3.55 gears
33x12.50 general grabber mud terrains
previously straight mall crawler body(now needs new fabbed rockers SEE BOTTOM PIC lol)
renix 4.0 w flowmaster exhaust
aw4 tranny
160k miles
cold air
daily driver/ trail rig
I forgot if I posted in this thread. I searched and didn't find anything so here goes. First the list.
36" Super Swamper TSL Radials
K&N Drop In
PowerAid Throttle body spacer
Rubicon Express>
Front
7.5" front coils, Drop backets with supports, Adjustable upper control arms w/ Super-flex joint, 3" lower bumpstops, Extended uppper bumpstops, Fixed Lower control arm w/ Super-flex joint, Adjustable Track Bar with hiem joint end, Stainless steels brakelines, Shock eyelet conversion
Rear
1.25 lift Shackle,Stainless steels brakelines, 6* shims, 11 inch resivior shocks
TSM MFG>
D44 rear disk brake converison
Rusty's Off road>
6" Leaf pack, 6" drop pitman arm, 1" blocks
Stainless Steel Air lines for both front and back
Conferr>
Conferr Rack mate with custom floor
Bilstien>
Front 11 inch Resivior
ToysbyTory.com>
Alumi-Tie Rod
Dana 30 Diff gaurd
ARB>
Compressor with quick connect adaptor for tire hose
Air locker for D30 Front end
Air locker for D44 Rear end
Safari Snorkle
Garvin Wilderness>
Rear bumper w/ 2 d-rings, swing out tire carrier, Jerry can, axe/ shovel holder, High-Lift Jack, cb attenna mount
Custom Rear frame stiffener
Warn>
X8000i Winch
Rear diff gaurd
Strap
Wiggles>
Custom front driveshaft
High Angle Driveline>
Custom rear driveshaft
www.Rigidco.com>
FBW2 Front Bumper with frame stiffeners stuffed with Warn X8000I
Galaxay CB radio Peaked and tweaked w K40 attenna
CSF>
3 core Radiator
FlowKooler>
High Flow Water pump #1747
Robert Shaw>
195* thermostate
Rock-It>
High flow thermostate housing
Borla>
Headers
Cat back... both fully T301 Aircraft SS
Magnaflow>
Cat
Boush>
Platium +4 spark plugs
Distrubitor cap
Fiveomotorsports>
Mustang 5.0 Fuel Injectors
Select>
Orbital Gell battery
Borg Warner>
7MM Resistor Spark Plug Wires
Mean Green>
High Amp Alternator
Gear Reduction Starter
XJARMOR>
Fan override
Rocky Road Outfitters>
Front & rear Bar pin Eliminators
Hesco>
Adjustable Fuel Regulator
MSD>
High Output Coil
H4 headlamps upgrade
Farmboy Desgins>
Rear Tail light housings
Custom LED package
Currie>
Steering box brace
Upgraded Aux fan from 97 XJ
4x4 Trail Hunter>
2"x4" slider replacement with extended tubing
Alloy USA>
D30 Axle Tube Seals
Cromo Rear Axle Shafts
Cromo Front Axle Shafts
Custom>
Rear bumpstop extentions w/ Daystar poly stop
Main fan removed and replaced with 14" Zirgo electric fan
Rear bulkhead stiffener
Advanced Adapters>
Slip Yoke Elimator in NP231
Tera Flex>
TeraLow 4:1 for NP231
Extended E-brake Cables
and a ton more...
Things To Do:
PARTS THAT HAVE ARRIVED AND ARE WAITING TO BE INSTALLED
Rusty's Gas Tank Skid
New Gas Tank
Superflex Speed sensor
Carbon Fiber Dash Inlay
8" Delta lights
Front Turn light bezels
Future mods...
62mm Throttle body
New seats
Rino lining of body
Roll cage. IN or out?
Dana 44 Front Conversion
AGR Hydralic steering set up
Transfer Case skid
Custom Crossmember
Cutting more from fenders
Custom Half Door> I'm doing this currrently
This is a baby pic of " the Problem Child"
Hey guys just gonna show off my xj i bought it a couple years ago and started lifting it and cleaning it up. did a few mods to it, but i didnt have much money so i went the cheap way with most of everything. its a 1989 jeep cherokee limited 4.0 with 156,000 miles on it. nothing special just want to post the pics since i just bought a camera a few months back and finally got it street legal.
in a few weeks i hope to get it painted silver and remove my "homemade" light bar, and replace it with a real light bar and kc driving lights. its got a 4.5 inch rough country light with AAL (wish i didnt go the cheap route now), ebay intake, exhaust pipe goin out under rear passenger side door. as i said not much has been done, had money problems in the past couple years but that has changed now. i just want to make it a light trail jeep.
