SketchyXJ
- New Jersey
The ball on the end has needle bearing in it right?
SketchyXJ said:The ball on the end has needle bearing in it right?
SketchyXJ said:If I already have a Hack and Tap installed can I replace it with another SYE?
The reason I want to do this is because it was hard for me to find the yoke with the ball that bolts up to it, and I would like to have a more servicable driveshaft. Does this sound like a good idea? Any suggestions would help alot, Thanks.
SketchyXJ said:really? its a spicer 211229X? were I am I cant seem to find it.
Is there any options to look for a spare one of these at a junkyard?
SketchyXJ said:Sounds good thank you, I'm going to order it ASAP.
And possibly build a spare. Thanks again.
UNCC_99XJ said:Ok...been searching for a few hours on SYE and want to make sure I have this right.
The plan is to ditch the 3" BB I have now and upgrade to a 3.5" RE kit. I've been fighting vibes for about a year now. Got the vibes straightened out today, but have some lovely axle wrap happening now as a result of the blocks on my current set up.
Since I have a NP242, and my Jeep sees 95% highway at trips of no less than 30 miles one way, and no really hard core wheelin, so here's what i'm thinking. RE H&T to run a front shaft out back. To get it to mate, i'll need the spicer with the part number listed in this thread.
-RE H&T
-Front DS from another automatic XJ
-Spicer
This is all I need correct? Trying to set the money aside now and making sure i'm not missing anything.
Maverickj1 said:I am getting ready install an RE Hack n Tap with the Spicer part and a driveshaft I got from pick n pull. Should I replace the u-joints on the driveshaft I just got? How do I know if they need to be replaced? :dunno:
Your front driveshaft should bolt right up to the PORC (www.PerformanceOffRoadCenter.com) SYE. No need for the Spicer part.
HTH,
Billy
PS - I almost deleted this thread for being a pic request, and see... you didn't need to see a pic at all
Yeap,its the HD kits that use a std cv yoke driveshaft.It seems like to me, if the PORC part eliminates the need for the Spicer adapter, PORC would be a better way to go than RE. I'd like to utilize this setup on my '99. When I look at the 96+ SYE from PORC, it appears to be a drive flange, just like RE's, so it would still need the Spicer adapter. Am I looking at the wrong SYE?
http://www.performanceoffroadcenter.com/oscommerce/product_info.php?cPath=37_42_949&products_id=154
Thanks
