www.jeepin.com--------project jeeps-----------rubicon express lift------click on them in this order and it will lead you to pics. Also try using www.ilovejeeps.com and tiffster there has pics and a write up that was hard to understand for me. Once you actually figure out how one side of the mounting brackets goes on, the other side is easier, but they are a PITA!!!!!!!!!!!!!!!!! The jeepin.com pictures helped the most and good luck, you will need it!
I'll second the PITA!!!
However it was worth the trouble.!!!!!!! The ride is great
Set aside some time I thought it would be quick and easy. Be patient and you will love them. I used the Ilovejeeps write up and it helped me a lot if for nothing else then knowing I wasn't alone in may frustration.
Good luck
Barger
I would agree, the ride and flex is excellent. Best advice: leave everything as loose as possible until its all together, then snug it all down and then tighten. And where the instructions say something like "if everything doesn't align then adjust." be prepared to "adjust" with your grinder, drill, sledge, etc. Good luck.
