HaleYes
- Clay County, IL
I got a good buy on a RE adj. trackbar. I have the stock TB off and rady to install the "new" one. On the RE instructions on the net it says to reuse the stock hardware on the axle end. The last thing I need is a case of DW, The stock bolt on the axle end is much smaller than the diameter of the RE trackbar. It fits tight on the stock TB. Maybe I'm missing something here, I don't know. Just dosen't seem like it should be loose like that. I took pics to help explain. Notice the gap between the bolt and the sleeve on the RE TB.
Stock TB is a good snug fit.
Any help is welcome. TIA
Haleyes
Haleyes
