RockTracXJ
- Colorado Springs
1-10, I say 9.7
What say you?
What say you?
The picture is awesome the quality sucks, what camera did you use?
I like it, but I'd use the 2/3 rule and put the Jeep off to one side and pan out a bit. The eye is confused by the action of the waterfall above as it naturally moves from left to right and left again when contemplating the content within the photo. Also, the contrast is a bit troubling. I know you want the Jeep as the main subject, but it blends into the background too much and the abrupt edge of the gravel road is disconcerting. I also agree with the previous comment regarding pixelation.
I rate the Jeep a 10+, however.
Some very fast photoshop work, but you can see where it is going:
But it is a good shot, I would give it a five or a six out of ten.
#1 - I agree. Most people have half-blurry crappy cell phone pics.It seems there can be a couple of ways to rate:
1. Against other pics, the pics you generally see of Jeeps on here, other forums, from your buddies, etc. Using that I'd still say my pic stacks up well, at least in the 90th percentile.
2. Against the ideal, how is the composition, lighting, colors, background, etc. In that case, I'd probably give it a 7-8.
I do like those changes, they make the picture better. But at the same time it seems like something was lost. That's not a real picture anymore, it's some gray area of picture and creation. I think both can be good, but the purist in me wants the picture to remain as the camera captured it.
This tells me that your photo was one of several taken that day of the same scene with the main variation being the people or vehicle in the photo. You are more likely to wow your audience with a unique subject. It is not unique if you have to compete with the masses to get your photo. If your subject is common then making a pleasing composition with it will help it stand out. Groupings of 3 is always pleasing to the eye. Try cropping your photo as a vertical to create a group of 3. You will loose the spent flowers and fuzzy pines on the right side of your existing frame and create a nice, simple grouping of three for the eye to follow through your photo: jeep>single tree>waterfall. Simple is good, viewers do not have to work to enjoy your photo.Also, as a bit of background, I had to tell my brother to back his Jeep out of my shot and I had to get the shot quick before the next group of tourists pulled up, hopped out, and started milling about, so my composition time was pretty limited. The falls in the background are Bridal Veil Falls near Telluride.
