mvickstrom
- Charlotte, NC
My 94 jeep cherokee 4.0 randomly will not crank. When turn the key I can hear the Starter relay clicking but then nothing. The nuetral safety switch has been replaced in the last 6 months. I took the starter off to replace it and took it to Autozone and when they tested it, it worked so i didn't replace it. I cleaned up and put it back on. After repeated trying and waiting it will start. Is this the ignition switch? Or is the starter going bad? When I test the voltage at the battery terminals and it is 13+ and the connectors are tight and i have cleaned them both. The starter has 13 volts when the key is not turned between the top terminal and the ground terminal. Any ideas on things to try? I would take it into a shop but its a random problem and I really can't afford for them to just start replacing things. Thanks in advance!
