Some random OEM bracket washer thing, pretty sure it is part of the rearmost exhaust hangar for a 96, part number J5358978, brand new in bag, FREE
97 and earlier AW4 output speed sensor, FREE
96 and earlier AW4 4x4 rear output housing, FREE if you trade me a busted transmission with the same 6 bolt pattern on it, else I am cutting it in half. This and the OSS above are useful if you have a 98 and later AW4 you are trying to swap into a 97 and earlier XJ and want to prep it before pulling your old tranny out.
And I have 3 VSSes (various years) and at least 6 speedo gears sitting here on my desk now, a flat-pin 3 pin, two round-pin 3 pins, a yellow 30 tooth (I may need this myself), dark green 34 tooth, orange 35 tooth (x2) and long shaft red 36 tooth (x2) speedo gears plus probably others I haven't found around the house yet.
Speedo gears and VSSes are $10 or a sixer each.
Also have a RENIX era speedo gear takeoff housing (the bit that goes in the tcase and gets clocked depending on what gear you have) for $10.
I am sure I will find more of these lying around as I clean up/organize things a bit.
EDIT: starter motor off an 01 Dakota with a 2.5L and an AX15, this is the starter you need if you are swapping an AX15 behind a 4cyl in an XJ/MJ. BILLY stop parting out your MJ and I'll give this to you for free. Anyone else, $10
EDIT2: CPS off an OBD era XJ, not sure which, it has an oval connector with 3 round pins in a row. $5 or a good joke (that isn't my jeep)
