Random Jeep Junk
Unearthed
West Point, NY
I need to get rid of some of this stuff as it is just collecting dust in my garage. As of right now I am firm on the prices but if this stuff does not move I will think about dropping them down.
1. 4 recently balanced (400 miles ago) 33x12.50r15 TrXus MT's - $500
The wheels are the standard bolt pattern for jeeps, 15x8 3.75" backspacing AR D-holes, although I bought one new in Feb to replace one that was bent (I still have the bent one and it still holds air so if you buy them at this price I throw it in as a spare wheel)
2. Bushwackers for a 4 door XJ. I removed these because I just never got around to liking them. I do have some hardware, but not all as certain bolts were frozen in their holes. They have the standard trail scratches but nothing major and there is one hole that is slightly enlarged. - $300
3. Window guards, good if you like driving with your window down when its raining. No adhesive required, they simply slip into the top of the window tracks. -$20
4. Shocks for about 3" of lift, I looked at them this morning and calculated roughly 25" extended and about 17" collapsed. The bushings on the axle end need to be replaced, although they still function they are just a tad noisy - $15
5. Shaft and associated parts off my 96 np231 case. - $15
6. 2 stock radios from a 98 and 99 cherokee - $5 each
7. Drive shaft from my old transfer case that exploded, will need to be rebuilt as I think the centering ball being lose was one of the major factors of my transfer case incident. - $15
Not pictured:
8. Passenger side tail light for a 97+ - $20
9. Spacesaver spare - Free
All items will be, as of right now, are PICK UP ONLY and located in Highland Falls, NY (right next to West Point).
how many miles / wheeling trips on the tires? i may be interested in them
probably about 5 wheeling trips on them with no cuts or tears, I primarily drive on the street (back in forth to school) so I'd say there are around 20k on them. There is one plug in one of the tires, but I have aired down to 13 psi with no issues.
