Radius arm clamps?
Nick_n_ii
Shelby, Ohio
Does anyone make a aftermarket Radius arm clamp for the late 70's HPD44 with the wedges on it?
Planning a build and want to build custom arms with the Ford style clamps..
Thanks
I just used the factory ones and cut and welded them. No problems. I even wristed the passenger side.
No, they are cast and you can weld to them fine.
No. I have welded several.
I am running a 78 Bronco front axle with modified Ford radius arms. It works sweet and was about a cheap a D44 as you can get. I've run it for years.
Are the bolt patterns going to match. Mine was from a Bronco, so it is a 5x5.5" pattern.
You are aware that you can get C bushings that have various angles.
Yes I know about the bushings found those in searching a few days ago..
Bolt pattern.. Right now the D44 is a 5 on 5.5, the FF60 is 8 on 6.5
I'll be hunting down all the parts to convert the D44 over to 8 lug. Seems around here the Rims are cheaper. And I just plan like the look..
