In an effort to remove the screws holding the rear shock bar pin, I of course managed to rip the heads right off.
Fortunately, I did this on the driver side where the clearances are better. Now I'm gingerly working the screws in the passenger side with Liquid Wrench and a ratchet.
In an effort to avoid cutting through from the inside I plan to do the following:
a) Center punch and drill the center of the screw out
b) Liquid wrench the bolts yet again and wait a few minutes
c) Work an EZ-out into the screw and see if I can easily remove the bolt, making darn sure not to break off the EZ-out
d) When c) doesn't work, drill and tap the holes
e) Use anti-seize on the new screws
So here are my q's:
1) If the EZ-out DOES work, I will chase the threads to clean out the crap, but what is the screw size: looks to a 5/16 something
2) When the EZ-out doesn't work, what size tap are people using when going the drill/tap route?
3) What screws are they using to replace the old ones? Shank length too?
4) Any tips on drilling/tapping as I've never had to do it before?
I will be using a tap with a T handle and 3 and 1 oil with the tap.
Thnx much
So here are my q's:
Thnx much
