...,would doing the front or rear be better for offroading? Or do you have to install front and rear at the same time?
If you're not planning to re-gear any time soon, take your pick. "Locker in the front will be less noticeable ON-Road(If you've never driven a locker equipped truck on road, there are some quirks
But do some research here. What gears do you have, and what rear axle do you have? Are you planning to re-gear any time soon? The carrier break for the front axle is 3.55/3.73. The carrier break for the rear depends on the axle. If you want to re-gear later, and have a a Cry 8.25, do the rear first, as the locker you get will work for any gears you buy.(carrier break for a 8.25 is around 2.54; any gear in a jeep is already lower then that, so it doesn't matter)
If you're planning on re-gearing soon, save up and do it all the same time. Doing a locker install (labor) is about 1/2 the price of a full gear setup. It's bad enough to pay for the locker install, then turn around and pay to re-setup for gears, you may end up buying a new locker because the new gears need a new carrier.
Also, if i dont intend to do any rock crawling, is it still a good thing to spend money on?
A locker(front or rear) will make a serious improvement off-road. I locked my CJ-5(rear) and almost quit using 4WD. If you don't do a lot of off-road, and don't go in the rocks, you might consider a Detroit Tru-Trac(gear driven limited slip)
Most people here will say get the locker, but the L/S preforms extremely well as long as you keep both tires on the ground.
