Atl-Atl
- Castle Rock
OK here is what I already have trimmed, you can see it in the pic
Now what I want to do is trim a little bit more. I want to trim off the extra lip that sticks out and is roughly 1/2-3/4 of an inch. Basically I want to trim up just to under the ridge where the holes are that mount the stock fender flares. I want to be able to put my stock flares back on whenever I please, but heres my question. Do you think that the fender will lose its strength as far as the plate that holds on the flare is concerned? Does the plate use that lip to ride against, or does it just look like it would? Do you think the flares/mounting plates would hold on solidly with just a flush mounting surface, without that ridge in other words?
