Andy in Pa.
NAXJA Member #180
- Downingtown, Pa.
I know a few of you guys are running them inside your front coils, how did you locate them so they stay centered in the coils? I am thinking of welding a small piece of tube approx. 2" high to the center of the coil spring pad, then slipping the prothane over that. Then doing the same for the top with a small piece of tube that will slip inside (again), with a round flat piece close to the size of the OD of the prothane (1/2" or so smaller) for the bumpstop to hit.
Is this what you guys have done? Seems like it would work to me, but just wanted some input from other locals...
Is it worth putting a pin (1/4" gr 8 bolt or similar) through the prothane/through the tube to keep it from coming off the tubes on either end? It seems that the pin would help more than hurt... thoughts on that?
Thanks!!
A.
Thanks!!
A.
