Ok ive gotten a "no they wont work on a crawler" to "yes they will"... :dunno:
the 10" ones only cost a little more and are ready to ship (when i bought them)
the other sizes took 18 days.
not an issue for some people, but somethign to consider.
i ultimately used 5" per side. 3" lift and 36's. but it depends on what you make for them to compress against
i would be safe and get the larger ones, you can always cut them down to the right length
I used the longest Prothane insert, which I thought was 10", and I cut one ridge off of them, which I thought was an inch, so mine are 9" long. The 9" Prothane insert compresses 3.5", and there's about 2.5" of travel before hitting the insert.
there is some info somewhere about how much they compress, a percentage of their height. if you find out how much they compress then you can do some math and find out the right length you need
They will compress more than that, I was running a one inch gap with 5-6 inchs of up travel on shorter prothanes and I could still bottom the shock out. I would do what goatman did and run plastic inside the prothanes to make a deffinent stopping point.
60 % sounds more like it, I am currently running my prothanes 7.5 inches long with a 2.5 inch gap and they only compress 1.5 inches until I hit the solid plastic inserts I put inside the prothanes. I could cut 3/8 of an inch off the plastic inserts to use more of my shocks but you can tell in the picture that I have about 3/4 of an inch more travel I could use by looking at where the rubber bumper sits on the shock shaft. Don't use any of my measurements either because I have custom coil mounts and bumpstop plates
Previously the prothanes were 8.5 inchs long with no plastic bumpers inside them and I could bottom out the shocks hitting a big bump.
