schmiedel
- Mexico (Querétaro)
Why use a V8? Better get all the power you can get out of a 4.0L and modify your transfer / gears / driveline to get all the torque you need and spend the money in a banging suspension.
ross said:im talking reliability as in driving it everyday for road use, it will just be used a couple of hours a week. and the motor that is in there (broken crank) was carb'd in the first place. i was looking for real advice not people trying to dog me for a solution to a problem i thought of
CRASH said:I got excited when I saw a V-8 swap thread.
I thought someone was finally stepping up to the plate to do a nice overhead cam engine. Something like a Lexus 4.7 or a 5.4 Ford.
What a let down to see we are dealing with sixteen pushrods and a 100 year old induction system.
Yes it can be done, yes you can do it cheap, yes there will be major headaches along the way. And in the end, you'll have a less reiable, less responsive powertrain than the 4.0 the XJ came with. Oh well, take pics of the swap whe you are done.
ashmanjeepxj said:I worked on it for 9 days last week on my vacation and didnt get it done, it is very hot here 110 so its tough this time of year out in the garage.
no way in heck would I give up an overdrive tranny for a C6 !! ,jlake1 said:I would vote for a V8 swap. And I HAVE done it. 5.0 in my 90XJ. Now, I will admit that the 5.0 is probably the EASIEST motor swap available, but here are the pluses:
- cheap
- runs cool (very important on an XJ)
- small
- lighter than the 4.0
- readily supported by the aftermarket
- runs upside down if you want
- 5 wires make it run
- can run on the intank fuel pump
Also, for those who say that you have to spend $7000 plus on a V8 swap....I guess if you are going for a new LS1 crate motor, maybe, but here is a rundown of what I spent on my swap:
5.0 - $550
C6 w/ B&M shifter - $300
NP205 - $Free
MORE motor mounts - $179
Electric fan setup (1 stock aux., 1 cheapo electric modified to fit the GoJeep! shroud trick) - $150
DC Control fan controller - $150 (this thing is baddass! Jeeps stays right at 210 all day long, even beating on it in the sand with temps of 85+!)
Fuel lines and adapters - $100
Autometer gages - $250 (I think this should be in here because it's required with the swap)
Misc steel, wiring, etc - $200
That gives me a grand total of just under $1,900.
Of course, I spent some more money on a new torque converter, higher amp alternator, etc., but I really don't think that should count in the swap cost.
Anyways, to each his own. I still think strokers are cool. I just wanted to post some real world numbers and impressions of a person who did the swap.
Thanks,
Jay
Ridr said:no way in heck would I give up an overdrive tranny for a C6 !! ,
