ROKRWLR
- Arvada, CO
How did you move the steering box?
I was running a longer waggy pitman arm to match the knuckle throw on my HP44 high steer arms. With a 3" or so stretch, the pitman arm and track bar had a slight conflict at full stuff which is why I did the box move.
I had JKS steering box reinforcement brackets which helped give me solid foundation for the move. I re-drilled the holes about 1"-1.5" forward and cut a hole in the cross member for the face of the round part of the PSC steering box to fit through. The face was about flush with the front of the cross member in the new position. The 4 bolt PSC box may have been bigger, so a stock box might not even need the hole.
I can't remember if the joint in the steering shaft had enough slip, or if I cut it and welded an extension in?
All in all, it wasn't that big of a job.
