blondejoncherokee
- sacramento
ok perfect, yea ill really need some new ubolts, .25in difference is too much :gee:
ruffstuff U bolts or any 5/8" set is always good. don't want to get stuck welding a U bolt on the trail.
Jons got it! Lol friggin jeepapedia.
Even if.. U bolts stretch so typically you wanna get new ones.
I hate 8.25s. It hasn't broke but with the gears I've had setup the pinion nut tends to back off changing the depth and creating a howl. Not to mention a c-clip rear isn't fun to change a shaft. As I'm sure you found out with that 35
ruffstuff U bolts or any 5/8" set is always good. don't want to get stuck welding a U bolt at the trail head.
Fixed it for you
Fixed it for you
Those bottles dont have the modifer. They just say they can be used to top off a lsd diff. Way different. Royal purple makes a gear oil with actual lsd addditive though. . Amd you dont want it. Dont bother with the mopar additive either . It allows the cluthces to slip more so it chirps less on the street. I use 80-90w or 85-140w in my 44lsd in my mj. No additives.
And the clutches not slipping doesnt hurt anything? And which weight would you recommend the most? No cold winters will be seen by the d44(like midwest style winters)
I'm not sure how I feel about not running the friction modifier. I was told by a few fellow members not to run the modifier to increase the friction between the clutch plates thus making the LSD lock up tighter for more traction. After a couple years, the LSD now makes a god awful chattering noise when hot and making tight turns. Some fresh Valvoline gear oil that comes with the friction modifier already in it made the clutch chatter significantly quieter but there is still permanent damage. Wether it's from not running the modifier or not - who knows, but in the future I will run friction modifier in my LSD rear ends.
Edit: the clutch plates still slip if you don't use the modifier, it just takes more force to make them slip and the slippage is less smooth.
