Project resurexj
Kego814
As some of you may be aware, my family got t boned and rolled in my last xj.
So I'm starting over.
I'm going for a 6 inch short arm with drop brackets all over.
Parts I have; a definitive list.
Bastard pack
3 inch front coils
2 inch shackles
2 inch spacers (I'll figure out what I'm going to do about that extra inch later)
Np242
I'll worry about pretty later.
I'm doing spacers and shackles today so I'll post pics later
As I am preparing for my b
udget boost I had a little side project. I ordered greasable shackles but the came without fittings or bores. So I drilled and tapped some holes. (Bushings have grease veins)
no, because that would be sketchy as hell.
a good leaf pack with a good shackle angle will be worlds better than any sort of articulating shackle.
A set of relocation brackets and those shackles will do everything you are wanting to do.
Check the MWC classifieds :D
at one point teraflex made Z boxes. get them both and then I'll wheel with you. I'll bring the camera. hahaha
really though that would be even more sketchy. The unloading would cause some intense butt hole pucker and possible a flop. they are also known for killing drive shafts
The concept of revolvers makes sense until I think about the front leaf mount. Anyone make a pivot for the front?
Sent from my MotoG3 using Tapatalk
Forgot to update last Saturday, but the budget boost (less shocks) is on. Not going to worry about shocks for now because all my springs are a bit sagged out and until I rob the springs off my old one I'm not concerned. My primary concern is driveshaft length on with a 6 inch short arm with the 241j Hack n tap SYE. (Opinions on Hack n tap over true SYE not needed.I get it) lol
What's the plan to make it.....not....um....Pancaked? This is a genuine question. The Jeep looks pretty bent.
Or are you building a different one....
Hahaha no that's the old one. Pics of the new one are coming as soon as it's tolerable to be outside for more than a minute
So I've got my np242 in and I got to thinking about driveshaft options. Aw4, 242 and 6" lift. Could I modify a jk driveshaft to have a double cardan (we have a drive line shop a couple miles away) and use that slip shaft? I've searched and haven't really seen any info on the subject. Without getting in to a true SYE discussion. I understand it's way better and I'll deal with it down the line but I have a ton of parts occupying my tool box top and I want them off lol so for now just a HNT SYE
