So time for another update.
So was having an issue with this thing idling due to the cam. After some reading, more reading, a couple of calls to my tuner and reviewing the timing tables below, we decided that since the cam is so large, it needs more air. My tuner mentioned that he is really surprised since he originally commanded 80% more airflow over stock during idle, but it still wouldn't run without throttle input. So now, we are at over 110% commanded airflow during idle condition with a couple more degrees of base timing to get this thing rolling.
Right side was the refined tune and left side was 3+ degress of timing during idle rpm to see if it would run. I flashed the tune, but we still had an airflow problem. So back went the PCM to the tuner in order to flash a revised tune with the new goodies I decided to buy.
In reference to those goodies, my hood wouldn't close with the truck manifold on top of the engine. To solve this, I spent money. Unfortunately, A LOT more than I should have, but meh.... screw it..!!
This. thing. is. ****ing. gorgeous.!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ...........and MASSIVE..!!!!!!!!!!!!!
I only have a couple beefs with this thing. For the amount of money that they want for this thing, they require you to actually drill a damn hole for the MAP sensor depending on what style of hole you have. Then, since you drilled into the damn thing, you have to split it the manifold in half to clean out all the shavings and put it back together. Its not really that big of a deal, but I feel its an option that should be included for the price. The other beef I have with this is that the throttle bracket is separate and not included. Not only is it not included, but the style that this manifold requires for the cable setup, I had to fab a custom bracket to move the cable up about 1.25". Again, not that big of a deal but still unfortunate. If you get a DBW setup then this doesn't apply to you.
So I got all the packages yesterday, tore everything apart and started the install. I played hookie from work today and I finished the install. It wasn't so bad, but I had to redesign a couple of things. The throttle cable, as previously mentioned, the intake(again), fuel rails, injector connectors, PCV and re-routing of some harnesses/hoses. Here is the end result.
AND................................... now the hood closes..!!!!!
Something I didn't take a picture of is the upgraded injectors. Since the cam is pushing so much air into this thing, I figured that the duty cycle was probably gonna get past 80%, or the "norm", safety margin with the stock 24lb/hr injectors. So I upgraded to 400cc, which is about 38lb/hr, Bosch red top injectors to compensate for fuel and keep the duty cycle happy. They were a tight squeeze and the body slightly touches the manifold, but they "fit".
Here is a random pic off the internet.
Lastly, since I went from truck injectors to LS1 style injectors, I had to convert from multec 2 to EV1. I ordered up those little pigtail adapters that you just plug in, but they made the harness super long, which looked stupid, and they were junk. So I returned those and busted out my google mojo and ended up finding these painless connectors that you wire in. They are freaking gold and cheaper too! Super easy to do, great instructions and cleaned up the harness. Hardest part was not destroying your back leaning over a lifted jeep. I highly recommend them!
Anyway, PCM comes back from the tuner tomorrow. So I am going to slap that thing in, prime the fuel system to check for leaks and let her rip. Hopefully I can get that thing running well since it sounds soooo awesome idling!
